using solo and 2 up seat
for changing seats, I use a solo with a rack most of the time and would like to be able to use the 2 up seat on occasions, what do you use to protect the fender in the back under the rear of the seat, do you put something on the seats so when you change back to the solo the fender is clean ? if so what do you use. this is on a fdx so the solo seat is standard, and the other seat would be the optional seat. looked at the bumper kit but think there must be better options.
I had the same issue with mine. What I did is had the local leather shop glue some thin rubber pad to the bottom of my 2-up seat to give the fender some protection. Worked great. You could also get some spray adhesive and put a double layer of felt on the bottom of your 2-up, I have a buddy that did that to his and it seems to work as well. I like the rubber pad because it keeps the seat from shifting when the passenger moves around.
Mastiff107
01-17-2017 05:41 AM
