Random Starting Problem '12 FXDWG
I have a 2012 FXDWG and on some start ups it loses power
1. Turn ignition on
2. Run switch on
3. Bike in Neutral
4. Fuel pump primed and red light on gauge is off
5. Hit the Start push button, get a loud click and lose all power for a brief second. Gauge display gets reset back to odm but doesn't erase time and trips
7. Hit the Start push button again and it cranks with no problems
This problem is very random and is about 1 out of every 20 cranks. I'm not sure if this has anything to do with it, but I've noticed a couple times I'm slowly rolling backwards when this problem happens.
Not a huge problem cause it powers right up after, but would like to know whats going on. Maybe a faulty starter relay?
Bike has 2000 miles and it started around 100
Mods:
Vance & Hines Short Shots
SE Stage 1 Air Kit
K&N Air Filter
SEPST
Factory alarm
1. Turn ignition on
2. Run switch on
3. Bike in Neutral
Mods:
SE Stage 1 Air Kit
K&N Air Filter
SEPST
Factory alarm
Yes, I also have this problem. I noticed when the bike stay i garage longer then two weaks, alarm exhauste the battery , and maybe (just i thinking) the battery have not enough power to start the engine. After all, I start bike after two weak without any problem, then If I stop after one minute or two and try to start the bike again this happens.
I'm going to go with a starter problem. Solenoid, relay or other.
A low battery is a low battery. It typically won't go from click to crank like you described. A loose connection might, but not a low battery.
The daily battery tender is a good practice. Especially if you do a lot of short rides.
