WG tire selection sucks
Does anyone know of a rear tire other than the $320 stock michelin scorcher that will fit on my wide glide? I have searched around and I have looked at the commander II which doesn't have the right size for the rear and I looked at the pirelli night dragon which is the right size but it is tubeless. What are you guys with wide glides running? Edit: I just did a search on J&P for the size and the only one that came up was the night dragon.
Keep in mind that you don't have to find an exact replacement. You could use a 170/60-17 or a 180/55-17 or a 200/55-17. It's already known that a 200 will fit a Fat Bob and a Wide Glide, they use the same frame/swingarm. You can also vary the ratio number to find a tire you like. Just keep an eye on the actual diameter of the tire. It should match as close as possible to stock, but as your tire wears down the diameter changes anyway. The diameter will affect the accuracy of your speedometer, but like I said that changes anyway as the tread is used up.
Hey guys I have been looking for a good all around tire for spirited riding. I ride my bike 30 miles round trip to "work" and then all over town, and the north side of DFW metro. I would like something that is grippy and isn't going to break the bank. I don't mean to intrude on Air Force Dyna Guy. thanks in advance!
