Reduced reach kit for forwards
Old 10-18-2013, 01:32 AM
clap's Avatar
clap
clap is offline
Default Reduced reach kit for forwards
I just put the reduced reach kit on my 07 Low Rider and it is just what I needed. But the brake pedal is still to high and I have no more adjustment. The threads on the end of the brake rod are not run down all the way to the main rod , it has about 3/4" of the rod not threaded. I was going to run my die down and add more threads so I took a tap and checked the size with the lock nut and it is 5/16" X 24 and the 5/16 X24 die will not work on the rod. It seems as though it wants to cut new threads. Does anybody know if it is 5/ 16 x 24 or is it metric. I do not want to screw it up , it cost me $144 for the kit. Does anybody have a 07 Low Rider parts book . It might tell you in there.
Thanks Clap
Old 10-18-2013, 01:45 AM
clap's Avatar
clap
clap is offline
I found what I needed , it is 5 /16 X 24 . My die must be bad. Will get one in the am
dirtdobber
10-10-2019 06:36 AM
ssleeper
Aerocharger
09-27-2016 12:26 PM
Maccam26
Dyna Parts
03-07-2015 01:49 PM
knightsofnii
07-16-2013 09:06 PM
freddyttt
02-12-2010 10:49 AM
Quick Reply: Reduced reach kit for forwards
