So after 4 years...
So after 4 years...
I finally got back to it and got it built.
Specs:
Originally an 88ci 2003 dyna engine, it's now a .010 over 110ci with 10.75:1 CR
S&S items: flywheels (welded). 'G' carb, 625g easy start cams, adjustable push rods, roller rockers and lifters.
Heads are ported and polished, as is the S&S intake manifold.
Cylinders and heads both have diamond cut edges, timken bearing and sleeve conversion, etc
Still to order: Barnett Scorpion clutch (unless you guys have better suggestions), Daytona Twin Tec ignition, misc gaskets (primary set) and bolts, and a decision...
Stick with the V&H Big Radius (love the look) or go to something like a thunderheader (don't like the look as much but I do like the performance claims). Here's how it looked before tear down:
Thoughts on the build and other suggestions/ideas?
