my 07 wide glide is cuting out
First check battery terminals, sometimes it could be that simple.
I would look at the fuel line and inline filter in the tank, people talk about it.
https://www.hdforums.com/forum/dyna-...fuel-line.html
All good advice. Loose and/or dirty battery connections are extremely common and everybody always swears they're fine. Bad grounds. As for the lines in the tank, lissen for a hissing noise in the tank when the pump primes at key on, that indicates a hole. Also running worse when it's lower on fuel. You can be sure if you do a fuel pressure test and it does not hold pressure after priming. My bike had a bad connection at a terminal for a fuel injector. As for the speedo diagnostics, are you sure you have the run switch on when trying it?
