Need wiring help
Need wiring help
Just replaced my handlebars on my 13 street bob. Also installed 2.5" tank lift after figuring out how dumb the wiring is going into the handlebar controls i just cut and spliced them back together with the new bars taped each wire heat shrunk tube after that (still using all my stock cables/wiring) i gently pulled a little slack on the wires to make sure i had plenty of room to splice. Anyway put everything together and turned the switch and only the headlight and tail light come on! Speedo doesnt work and no handlebar controls or signals.anyone know what i could have unplugged? Or what fuse might have blown? I ask because the speedo and everything is on seperate wires from the bars so i dont see the problem being my splicing.. Any help please and thanks!
I could be wrong, but I do believe the run/kill switch is on the same curcuit as the speedo cluster, if you have a short or pinched wire in your swap you might have blown a fuse. Best thing to do is pick up a service manual and read the wiring schmatic to help isolate your problem. Also, loosen the switch housings, change the fuse and power the bike up, if it all works, you have a pinched wire when you tighten up the switch housing. Make sure wires are clear and tighten one side up and with power check the fuse, then do the other side. Hope that helps, good luck.
Good advice on getting a service manual. In the mean time, get a piece of wood for support, remove the tank bolts, and gently slide it back a little. Prop it up on the wood, then take off the black plastic panel underneath. Your connectors are all up in there. Look one that's been pulled out. I had plenty of slack for my 2" lift and 12" rise bars, so you "shouldn't" have had any problems either, but it's worth ruling out.
I don't understand why you would cut the wires. You can take the wires out of the molex connector and it is much quicker then cutting and splicing wires. Did you solder the wires before you put the tape and heat tubes on them. If not they could have become seperated very easily. If it was me, I would do each wire over and solder them, check and make sure each plug is connected and every fuse is good. Did you pull the main fuse before you started working on it?
If you don't do your homework before you start a project, you will be doing it over multiple times.
Make sure before you move the tank back that you depressurize the fuel system and disconnect the fuel line to the tank...it is very short.
