Wheel Bearing
10-21-2013, 04:37 PM
Wheel Bearing
Skf 6205 2rsjem
Anybody running these wheel bearings in your dyna ? They are the exact same size as the harley bearing for 2008 dyna. The front wheel on my Fatbob started making a roaring noise when ever I lean to the left. Straight up of lean right an no noise. So I am going to replace the tire an front wheel bearings.
10-21-2013, 04:54 PM
I don't have any experience with those but if there is someway to fit the bearing from an '06-'07 Dyna that would be my choice. It will require a new axle as they ar 1" but it is a double row bearing and they are very durable. It may require taking the wheel to a machine shop though.
10-21-2013, 05:09 PM
Well worth it if possible. Should nt be too pricy to have the wheels machined
10-21-2013, 10:34 PM
i have them in my wheels... no problems
10-22-2013, 06:59 AM
10-22-2013, 07:08 AM
Definately going to do that this winter myself.
10-22-2013, 08:41 AM
Whatever you do make sure to use the right tools and don't press in the non-primary bearing(s) too tight against the spacer.
Ozark Joe
EVO
01-04-2017 12:39 PM
traildog
EVO
18
06-19-2012 09:33 PM
jimmers1817
06-25-2010 06:36 AM
Mochester
Wheels/Tires
06-23-2010 07:49 PM
groovy
07-08-2009 08:07 AM
