Ricor Intiminators with Traxxion Straight Rate Springs
#1124
Intiminators/Traxxions on 49mm Wide Glide forks
Been following this thread for quite some time, great information from everyone. But it seems as though most guys are riding Super Glides. Maybe I missed some posts but does anyone have any experience w/ the 49mm setup on a WG platform. Looking for suggestions on Traxxion spring length and rate. Looks like 44x365x.95 are being used a lot. Would the same recommendation hold for the WG with the greater rake. I weigh 200-220 and ride solo. Most of my riding is street riding so I like a softer ride to make up for the crappy road conditions, but like a well planted front tire on the rural twisties as well. Getting ready to order springs and would like some further advice.
#1125
#1126
For those wondering if the Works triple rated springs are the better ,all I can say is after five years they are still wonderful. If you ride like an old lady straight line perfect ride then forget the Works you don't need the extra but if you ride it like you stole it and have come across situations where you need that extra suspension like unexpected pot holes, curbs, hill climbs, or just motoring on them curves then consider the Works triple rated springs. After three years I removed and refilled the 10wt Amsoil and it was still clean. Same stock seals running fine. With the Riccors and the Works springs I ended up using 3 oz'S less each tube. 23 oz's. I had cut an inch off the preload spacers.
Solo rider 190 lbs.
Solo rider 190 lbs.
#1127
Solo rider 190 lbs.
Solo rider 190 lbs.
#1128
#1129
I think the difference between Racetech and Traxxion, primarily, is that Traxxion will make a custom length spring whereas Racetech does not.
#1130
