WG Kickstand Swap
WG Kickstand Swap
Just bought a -1" Arlen Ness kickstand for my WideGlide. I never have been comfortable with the lean angle since I lowered the rear suspension. Could someone post a step by step instruction for replacing the stand. Would make the job easier before I dig in. Looked for a You Tube Video, but none to be found...
Not too much to it bro. Just jack on the front mount enough to set upright. Then release the spring and pull the cotter pin, remove pin, then the kickstand assembly. After that just unbolt the "clevis" from the stand. Grease and replace the clevis. Reinstall in reverse order. IDK, kinda down and dirty. But as I said, not much to it.
