Rear LED Help
Rear LED Help
Anyone that is running led turns/ stop/ running on a 13 street bob please help me. I have joker machine astros on mine and i have blinkers and brake but no running lights. Ive tried custom dynamics eclipse and the badlands joker machine 2 to 3 wire converters and no success. what did you guys use? or where is the built in module so i can take it out
-B
-B
The eclipse aren't made for a Run/Stop/Turn setup when using the same light to do all three, tells you on the web site that it won't do the run function. What you should be using is the Custom Dynamics TrueFlex Dual Converter (TFDC). When using the Trueflex dual converter, you would run your ground wire from the bike harness for that light to the ground wire on the light (LED), then you would running light wire (should be the blue if they didn't change it) and connect it to the orange wire on the TFDC and then run the stop/turn Purple w/white stripe or brown w/white strip wire (left or right) wire to the red wire on the TFDC. I have been using these for a couple of years and they work great.
This might help you out.
