se 10mm plug wire loom ideas
You can also make your own, for the front cylinder support put a tie wrap on the ignition lead than insert the pig tail of the tie wrap through the hole in the top cylinder bracket, use another tie wrap head to secure it on the other side of the bracket like I did below on my clutch cable. The rear support you can use part of a large tie wrap, poke two holes through it with a soldering iron, and use two small tie wraps to tie the leads together.
