Street Bob's, how much rise w/stock cables/wires?
How much rise/ape height have you guys been able to achieve without changing the cables or wires? Had 12 in Burly narrow bottom apes with 2 in risers on my Super Glide, and it fit me very well, could ride all day without a problem. Would like to put the same setup on my new Street Bob (2014, so I can add regular risers), but don't want to get into cables and wires right now.
Thanks.
Thanks.
I just threw a set of 12" burlys on stock risers on my 13 SB.. was a bit of a juggle, had to reroute a few things but overall it works fine, just had to unlatch the throttle cable from that black metal latch/holder thingy on the upper tree. Had it for a week and done around 1000km's... no issues.
Slammer kit's next!
Slammer kit's next!
The stock bars are around 10" and the stock risers are around 2". With the stock setup you have room to play on the cables and hoses, and a ton of wire slack in the top tube that is tucked away. You even have room to play with the cables and brake hose so you should be fine going a couple inches over stock.
Awesome, I should have said I have 2 in. riser extensions, so I should be good. I had the 12 in. Burly's on my Super Glide, and the rise and pullback were just perfect for me with the 2 in. extensions, so I may change the bars out sometime. Will see how they feel with the stock bars. I noticed the factory ones seem to turn back a bit more at the grips. Weather here sucks, so I didn't really get a good chance for the feel on a test drive.
