Swingarm swap- want to keep the bearing races in place...
Old 10-28-2013, 12:19 PM
Architect's Avatar
Architect
Architect is offline
Received 4,871 Likes on 2,538 Posts
No part # here at work. It was made by HD for a couple of years around 2001 to 2004. Same time they went to 1-1/8" for all Dynas, it was offered as a retrofit for the older bikes. It was in the HD parts Catalog, my dealership had the older catalog, did a search and had one shipped to them.
It is just a narrower belt but with a rear pulley that has the needed offset and bolt pattern to fit pre-2000 wheels. As I recall it that was just the belt, rear pulley and all gaskets to pull the primary for the job. The only special part is the pulley, the belt is stock from the newer bikes. Of course the hitch is outer and inner primary covers must come off to swap the belt. I used the opportunity to also go with a open belt primary drive while I was there.
If not looking for that route, at least it would be a good excuse to chrome the inner primary.
Old 06-30-2015, 03:24 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
What year did the swingarm change? I was thinking about this swap for the same reason. I have a '99.
Old 06-30-2015, 05:30 PM
zimm's Avatar
zimm
zimm is offline
Up through 2005 works. 2006 was the switch.
Old 07-01-2015, 02:46 PM
cggorman's Avatar
cggorman
cggorman is offline
'99 is different than '05, tho. A Google pic search makes it's look the arm got the higher, thinner caliper support in '00. That makes me think a '00-'05 swingarm will allow me to use the smaller two-piston rear caliper.
I may end up going with the Wilwood low mount bracket and GP310. I can't find many pics, but it seems to look even cleaner than the smaller factory setup. cost is a bit more, but only a bit.
Old 07-01-2015, 03:15 PM
zimm's Avatar
zimm
zimm is offline
Exactly. 2000-2005 has the newer caliper mount. That's the only difference. Looks so much better with the twin caliper and cleared my saddle bags better too.
Michael Mott
12-27-2017 02:00 PM
Ozark Joe
EVO
25
06-19-2017 09:48 AM
richard567
EVO
12-20-2016 01:18 PM
WVChrome
02-10-2014 11:38 AM
cjbmustang
05-28-2011 06:38 PM
Quick Reply: Swingarm swap- want to keep the bearing races in place...
