Big bore kit w 96" heads good combo?
Do you guys think that if put a 95 to 97" big bore kit along w a stock set of 96" heads on my 88" it will perform pretty decently? i heads only have 10 miles on them an i can get them for free. already did andrews 26 cams an adjustable rods. Im NOT trying to break any land speed records here just want some more power i do alot of 2up riding.
There is a shop close to me. Rick only runs evo motors with twin cam top ends and cams.
His bikes are always strong.
I understand you are referring to a 88 twin cam. I was just showing that they do work. What kind of performance I don't know.
I would see if you can find some specs on both of em.
Check out this sticky. Harley Davidson Forums > General Harley Davidson Tech Forums > Engine/Fuel/Intake/Exhaust Harley-Davidson Twin Cam Heads Flow Bench Study.
I don't know how much HP & TQ will improve. It will be more then the 88 heads. You'll also be able to run higher lift cams. Main thing is to match your parts. Make sure everything works together. Don't forget you have to change the intake flanges
Before I sold my '03, I was going to do the same thing. You already have the heads, do the big bore, '06 heads, thinner head gaskets. Your'e good to go. Put the 88 heads on the shelf, save some $'s, and get them worked. Or sell them and recoup some $. IMO With the cams you have you wouldn't gain much getting them ported.
parts eeter
04-25-2013 10:02 AM
Karsten
Exhaust System Topics
22
06-12-2010 02:02 PM
markymark02
08-22-2008 03:58 PM
