RIP Ignition Module...2005-2013 (or is it really?)
Apparently my ignition module (32478-04A-05060 according to the sticker on it) died on me yesterday.
I took my bike to a car wash where I've had it washed a million times (family owned biz). They don't use pressure washers on my bike, and always cover the seat and the heavy breather cone.
So anyways, I proceed to start the bike after it was done...and nothing happened. After a couple of tries only one cylinder starts firing. I toy around around with the spark plug wires and it seemed that if I moved the rear cylinder spark plug wire a certain way, then both cylinders would start firing normally.
In the midst of the tugging and the pulling, I shocked myself a couple times, and then the "moving the spark plug wire" trick stopped working. I thought that either the spark plugs, the spark plug wires, or the coil were the problem...and there began my journey.
1. The spark plugs
Just slightly fouled
- I hadn't changed spark plugs in 2 years, (and they were in the bike long before I purchased it, the bike had been in an insurance wrecking yard for God knows how long before I won the bid)
- I changed both spark plugs for two new ones.
Still, only one cylinder would fire...up next, the spark plug wires and the coil...
2. The spark plug wires
- I thought the front cylinder spark plug wire was the problem, since the rear one worked fine (fired up the rear cylinder) I purchased a spark plug wire set from a friend and still only the rear cylinder would fire, so the problem was not the spark plug wire!
3. The coil
Since changing the spark plugs and spark plug wires didn't work, I worked up the ladder and thought the coil might be the problem. I replaced it with a used one and still only the rear cylinder would fire. Now I was getting apprehensive. Next stop: the ignition module
4. Ignition module
The part number on the sticker is 32478-04A-05060...I got a loaner module with part# 32478-04A-04380 (it was taken from a Softail)
When I tried started the bike, BOTH cylinders would fire, but only for ONE (4-stroke) cycle and then the engine would shut off. I did it 2-3 more times, same results, then they key symbol lighted on the dashboard for a couple of seconds...
This is why I think I need a new ignition module, a compatible one at least.
- The number of the module (printed on a sticker) says 32478-04A-05060
- The Ronnie H-D part finder suggests 32622-04
- When running that part number on the Lake Shore H-D shopping web, it turns into 32622-04C (an extra C)
- When looking through eBay for used alternatives or cheaper OEM, I get different variations of the 32622- but with a "-04A" or "-04B" at the end instead of the -04C suggested by the catalogs...
Which one should I choose? Any feedback is appreciated, thanks! Also thank you for taking your time to read thru all the ordeal...
1. The spark plugs
3. The coil
4. Ignition module
Thanks for the crank sensor trip. I agree with you and think the "throwing parts at it" solution is rather slow, but is there any other way of checking if electric/electronic components work? How can I check the ignition module aside from replacing it with another one and trying to start the bike?
I've also been suggested a couple more things:
1. Try the borrowed ignition again, but clearing the computer chip first
- Push and hold the odometer button and turn on the ignition key, then release the button...that forces the chip to "relearn" the bike (got this tip from a 07 FXD owner...don't know if it'll work)
2. Use compressed air to blow out any possible water residue from the "Delphi electronics" portion of the fuse box
- I blew air into the rest of the wiring and fuse box, but didn't touch that part of the electronics, it's worth a shot.
The reason the loaner module will not work but fire only 1 time an shut off. You have to do the password learn for that ecm to work with your bike.
http://www.harley-performance.com/password-learn.html
I have to do this each time I put a different ecm in the bike. You have to do this step by step an not mess up or you will have to start over again. You will also have to do the password learn to reinstalll it to the bike you borrowed it from.
