riser bushings
I used Alloy Art but I don't think it matters & HD poly bushings will work. Whatever you use, don't expect rigid stiffness as there will still be some flex (unless you go full solid bushings).
What studs are you referring to? Do the risers thread from the bottom or the top? If they thread from the bottom then just re-use the stock studs. If they thread from the top then I recall mine being around 2.5", but you'll have to measure. Top clamp should have it's own studs included.
What cables are you getting?
mfgarcia68
05-26-2009 12:01 PM
