Throttle cable retaining clip removal
I'm putting apes on my wifes new Super Glide and it's requiring longer throttle and idle cables. There are really small retaining clips holding each 45 degree in place on the grip housing and I wonder if anyone has any pointers on getting the clips on and off? Any pointers would be appreciated.
Grab it & carefully pull it out by hand. You might be unlucky & have some grief with either one of them, but they usually just come right out by pulling on the metal elbow protruding from the switch housing, while supporting the housing with your other hand.
Obviously remove the cable & brass ferrule from the throttle first.
Yep, they are spring loaded so lube helps.
Not asking this to be a smartass, but are you mechanically minded at all? Reason I'm asking is I did my own ape install too, & to be sure there are some tasks to this that are much more difficult than these clips ahead of you. (Clutch release cover mechanism and connector repinning come to mind) I'm a qualified technician with all the tools & even I struggled the first time!
Had to do clutch cable on the RK and it wasn't so bad, had a hell of a time getting the new cable threaded into the outter cover. I may get lucky and not need it on the FXD, but then again you never know till you button things up.
The last time I had to deal with cables was on my 98 DWG and been awhile but thanks for looking out for me.
So, while I'm asking dumb questions let me ask another, it pulls straight out...simple enough how about the reverse, just press em back in?
I am very capable and did my RK, but I haven't done throttle cables for years and I'm never too cocky to ask a dumb question....I prefer those to dumb expensive mistakes
As to the clutch cable threaded into the cover...here's how I did it some years ago:
When installing the new clutch cable into the cover be careful not to damage the threads in the clutch release cover. Here's how I managed to get in the clutch cable without any problems:
1. I hung the clutch cable from the ceiling in my garage using a string
2. Sat underneath it with the clutch release cover between my knees
3. Grabbed the threaded end of the clutch cable, inserted the cable end into the threaded hole and positioned the cable in line with the cover
4. Once the two threaded parts gott together, I first slowly turned the cable counter clockwise until I felt the threads falling together
5. From that point I slowly turned the cable's threaded end clockwise. When you don't feel any resistance you should be OK!
Yep, just press them in till they snap.
I'm going with Barnett cables and hopefully there will be no pulling out shenanigans ....thanks for the help guys.
No real hassles or puzzles, I cranked on some tunes and took my time, and things went just like they were supposed to...and I had a blast doing it...even those damn brakes!
And, I am not a, "qualified technician," just a mechanically inclined old fart with some tools and wiring expertise who wanted to do it himself...
scooper321
04-18-2014 11:05 AM
