Changing tanks to get guages
I have an 06 SG Custom FXDCI and I dislike the single speedo above the handlebar mount ala Sportster - have been looking for ways to modify the guage (and add a tach). I saw an 05 low rider tank for sale with the speedo AND TACH in the tank dash - me likey!
My question is: will the tank fit my bike (05 tank on 06 bike) and how much Frankenstein wiring modification is it going to take to make it work properly with both guages, tach included? Bike currently has no tach.
Thanks guys!
Thanks guys!
I believe in 05 you could get the dyna's in FI or carb (FI was an option)
What you want to do is compare the wiring schematic on your model and the 05 low and you will see exactly what you will have to change/modify. I can almost gaurantee you will have to legnthen the tripometer to fit in the tank console...the wire just wasn't long enough.
Once you compare schematics you can see what part of the wiring harness you will need to change out and price replacing some of the branches or do a little splicing.
You will find that most of the wiring harness is exactly the same. I took a 2007 FXD and changed it to a FXDC/ fat bob tank and dash. We kept the switch the same so we could put an emblem in the new dash. The speedometer was changed out to a 5" and we also changed out the bars to fat bob bars. The old speedometer was on the handlebars just like yours. If you can buy a dyna low FI tank then it will actually be easier for you because you can use your current speedometer. Here is a pic of the final product:
Be aware that while all 2006 plus and even the 04 and 05 FI tanks will mount to all 2006 plus dynas, that Dyna came with two distinctly different tanks. If you look at ebay pics you will see that the plate that seals over the fuel pump and sender is either rounded at the top or squared off. If you plan to reuse your existing parts, this will be important to you.
