Damn bug bit me!
Damn bug bit me!
Well with the recent posts on cams, the bug bit me and now I want to get one! Not decided on a cam yet, but I have narrowed it down between a couple.
What I need advice on is cam kits. Who has the best kit out there, i.e. what kit is most complete? Im talking gaskets, lube, loctite, hardware, etc.
I like the easy install rods, I dont want to go through the top. It looks like S&S has some pretty easy to install pushrods, are FM's just as easy?
Also, cam bearing pullers and installers, any place I can pick up a cheap (as in price).
I've read a lot of posts and watched a lot of videos. Even though I am not a wrench turner, I am pretty confident in doing this job on my own,
Hi,
i go back and forward with the cams,
would be good wideglidefever to see what the bare minimum is required for a cam change
i missed some andrews48H for a 96ci just recently, they seem to get good reviews, lots of choice
look forward to seeing how it goes
also I couldnt find a dynojet base map for close to my setup so could flash and then autotune, maybe a powercommander one
thanks
mirrmu
thanks
mirrmu
Hi,
thanks
mirrmu
thanks
mirrmu
I went to this thread an bought the remover/installer an bearings from Mr. Beatty. https://www.hdforums.com/forum/touri...ller-tool.html
Tool was easy to use to remove bearings an install the new bearings. Price was right around 100.00. E-mail him it is in the posts.
I used the Screamin Eagle adjustable pushrods an tubes with the tw 555 cams. It was easier job than I expected. Had to buy 1 gasket an 3 o-rings from Harley.
I bought the blind hole bearing puller from Harbor Freight...with a 20% coupon is still under $60.
http://www.harborfreight.com/blind-h...ler-95987.html
Maybe not the best tool in the world, but it worked for me and it can be used on many different sizes for something like a wheel bearing, etc.
Put the new bearings in the freezer overnight and tap them in...I have their seal driver set too.
[quote=RA51;11992201]I went to this thread an bought the remover/installer an bearings from Mr. Beatty. https://www.hdforums.com/forum/touri...ller-tool.html
My brother got this tool so I used for my change. Tool works great. I have the Andrews 48H cams and they are just what I was looking for.
I just put 222 in my 103. Still dialing in the PV, but so far the amount of power is very noticeable. S&s has a nice install kit that gives u the gasket, bearings, oil pump o ring, and circlip. EBay has them for about $28 I got pushrods from FM because u can use the stock covers which saves u a few dollars. I also changed lifters while I was in there too and went with gatermans. Pretty pleased with everything. One tip tho, with mine after adjusting, then readjusting the pushrods, I gave it an initial start and it was clacketing pretty bad. Totally thought I screwed something up. After pm'ing another member, he told me he had to take it for a short ride before everything quieted down. Well, since I really haven't seen anyone mention it, I will tell you that it took about 2-3 miles down the road before mine got quiet. I was pretty nervous until that point, but now I'm very happy with the extra power, and it really is as quiet as stock. Maybe a tiny hair louder, but overall very normal amount if noise. Btw, some say to use red locktite onthe adjustable rods, well I can tell you from experience that it is a big pain in the *** if you have to go back in and readjust . It was a fun project though, and well worth the time. Oh, and anyone that says the 222 runs out of gas in the higher rpms is on crack. Those things pull crazy hard well up over 5000 rpm.
