Starter options for 124" motor
Hey guys I picked up a dyna with a built 124" s&s setup...great bike but whenever the motor is cold (weather below 50 degrees)I just can't get it started even with a new battery. I have compression releases but once it cranks for about 10 seconds its dead. Any ideas on high output battery or starter options? The bike functions perfectly but I feel like there just isn't enough strength to those pistons in the cold.
So, it's cranking slow when cold, and better when hot?
A cold engine is physically easier to crank than one that is at operating temp. Once hot, everything is nice and tight. The oil will be thicker when cold, however, these are dry sump engines.
If it's hard to start after it's all cooled down, and cold out, I would look into the battery first, especially if it's dead after 10 seconds of cranking. I would also suggest looking into the charging system, just to be sure it is up to snuff.
The other thing, a good running, well tuned engine shouldn't crank more than a couple seconds before firing. Turning that big engine over for that long, is certainly not doing you any favors. It'll make your battery and starter worse.
Chase
Edit, try pulling the clutch when starting, and see if that makes any difference.
Chase
Since I put all that in if starts like a stock bike. I put a switch in where when I activate the decompressors, it kills the lights and all my power goes to the starter. Once it starts I just flip the switch the other way. The way S&S wires the decompressors thru the start relay you can actually feel the decompressors moving up and down as the motor turns over. With the switch that goes away. I spent 3 grand on this problem trying different starters, batteries and what not. What I listed here is the best set up to date.
Chainsawdomizer (02-22-2020)
Ridintolive
03-19-2013 08:41 PM
