Idle...how low can you go?
I have my bike set at factory idle reading anywhere from 970 - 1030 according to the tach.
I thought if I lowered the idle, it might sound a little better at idle.
What could I lower it to and still not have any problems.
On a 13 can I lower the idle and not affect the computer?
Only way to adjust idle is with a tuner that allows you to do so through the ECM...as someone else mentioned, do NOT mess with the idle screw!
You can idle it down some with a tuner, but the lower the RPMs, the less oiling you're going to have. IMO, on a modern HD anything less than 900 is too low for proper oiling.
Mine idles at 1,000 & I'll keep it that way.
do not touch the idle screw !! these are pre set to allow proper air gap around the throttle blade! It will F-up the tps readings and cause all kinds of issues!! Lowering the idle will also decrease the oil flow to the top of the engine during idling. Not a good idea......
