What is the fork width on a Wide Glide -10 up?
11-19-2013, 03:29 PM
Hi,
I would need to know how wide it is between the front forks on a Dyna Wide Glide 2010-up (FXDWG)?
Would measure myself but my bike is in winter storage right now and I need this info to know if my plans for turn signals will be legal.
Im sure this is Googleable information but I actually come up empty.
Thanks very much in advance!
11-19-2013, 04:01 PM
I think they are 10" tube center to tube center, but not 100% sure
11-19-2013, 04:17 PM
Sorry.. 9.875" on the old 41mm model.. But i am pretty sure that on the newer 49mm version, they just made bigger holes for the tubes, and center to center is the same.
11-19-2013, 04:21 PM
Quote:
Originally Posted by
Danish-chopper
Good guess.
Triple trees are 12 1/4" o/s.
11-19-2013, 04:24 PM
O.F.
Good guess.
Can you ellaborate? English is not my first language and I don't understand the "o/s" shortening?
Thanks!
11-19-2013, 05:06 PM
Maybe outer sides? "Utvendig.."
Havde inte set du var fra Sverige
halløj fra Danmark hehe
11-19-2013, 07:41 PM
pheur
Thanks!
Sorry....outside to outside dimension.
11-20-2013, 08:23 AM
So yes inside to inside is 8". 2011 FXDWG.
11-20-2013, 08:27 AM
11-21-2013, 01:08 AM
Bbbadboy
What's the law on that ?
In Sweden it has to be a distance between the turn signals. I need to check the exact measurement (I have heard two different numbers) but 8 inch between is probably not enough.
