Which fairing ?
I just ordered this one for my 07 SB: http://tsukayu.com/QuickDetachableFairingforDyna.html
It should be here this week and I'll post pics soon.
I am also using a Tsukayu Fairing but not the one for Dyna as it is suitable for smaller headlamps and i have 7" Headlamp. Recently there was a post where someone mentioned talking to them and they are modifying the Dyna Fairing for 7" Headlamp. If that is so, it would be the best solution.
I used the fairing for touring model and modified the mounting clamps to fit on the HD Quick release brackets which I had from my wingshield. Goes On & Off in minutes and does not leave anything on the forks when off.
I used the Memphis Shades #7011 "bagger" fairing which is designed for a 7" light. I had some custom metal
brackets made rather than using the MS ones and then fitted the Harley quick disconnect windshield clamps so
the whole assembly goes on and off in seconds.
Others have used the standard MS brackets and adapted them to use the HD clamps which provide a much
cleaner installation than the MS clamps.
I use a 14" Clearview "recurved"windscreen that I look through rather than over. Despite "common wisdom",
looking through rather than over works fine in all weather conditions except freezing rain, (and in those
conditions I ain't riding.. ), and also offers more weather protection in the high winds that are common in
the Southwest.
the Southwest.
the Southwest.
the Southwest.
(Superbrace) and I had to radius the inner bottom edges so that they clear the mounting clamps.
Not a big deal, but something to think about.
I'm going to get the clear fairing lower deflectors and install them this winter. If they work well enough, I'll
probably ditch the fork mounted ones.
But remember TANSTAAFL... There Ain't No Such Thing As A Free Lunch... this type of fairing does increase
drag; especially with the tall windshield.
Out here in the Wild Wild West, range can be an issue as once you're off the main highways gas stations
can be very far apart and it's worth noting that the set up I have is pretty high drag which not only reduces
the top speed to about 110mph, but also lowers fuel mileage at high cruising speeds.
80-85mph cruising speeds are very common out here even for little old ladies in econo-boxes, and at 80-85
I get just over 40mpg. At 60-65 I get 45+ so I can easily gain or lose 30 miles of range based on the speed
I choose to run. In more populated areas, I run at whatever speed is comfortable without worrying about it,
but in some real desert boondocks I'll throttle back to increase range. I normally plan on about 150-160 miles
between stops, but last summer I misjudged one segment and was down to about 1/2 gallon remaining when I
found a station.
This is a better view of my typical long-distance load-out and you can see that I'm about as streamlined
as a barn door.
I'm very satisfied with my setup for my needs, but it's something to consider if you plan on really long rides..
HTH
