Higher RPM vibration on the Dynas
Ok so Im on the Dyna forum a lot since Ive now got one in my stable....Mrs found her an anniversary FXDC and fell in love with the paint scheme. On her first break in ride she pulled up next to me at a light and said, hey I need you to test ride my scoot for me, theres a hellatious vibration in higher gear/RPMs. I read where people are trimming the top of the front engine mount rubber so I told her, yeah I read that was an issue but waited to see if your bike did that. I trimmed it and she stated it took about 75% of it away. I figured, cool. The other day I adjusted her clutch pack and decided to take it for a spin and damn if I eliminated 75% of it away and still feel the vibration as much theres got to be others who must be feeling it also, what the hell is that all about or is it I am spoiled to the four mounts my RK has and its the nature of the beast that uses only two mounts. Any solutions to this very peculiar development from anyone?
If none of the above does anything then well. .nature of the beast. Keep in mind the exhaust mounts to the transmission which is part of the engine. Different exhausts have different inherent vibrations they will impart to the frame.
It does vibrate the worst right at the shift points and after 70-75MPH.....just wonder if anyone has a fix, here I'm promising the Mrs now that she has a 6 speed instead of POS Metric 5 speed, she wouldn't be able to hear the engine at 80MPH like my RK that has the same engine and I don't like being a liar.
what exactly are we considering high rpms? and where are your shift points.
70 in 6th is 2500ish rpms
70 in 5th is 3000ish
70 in 4th is 4000ish
70 in 3rd is 5500ish
when i picked my fatbob up it i never used 6th until i was doing 75+ because of vibes.
since remapping i can ride it down to 50. the vibes doing 70 in 3rd are expected.
changing from the stock tommy guns to a propipe made a little difference. but i really think the stock map is far too lean at the low rpms. at what your feeling is the engine lugging
i'd be interested to hear if the op still feels the vibes in 4th at 70. or 5th at 80.
Let me give you some perspective. I owned and enjoyed seven different BMW twins from 1974 to 1995 and rode a few hundred thousand miles on them. My Superglide is just as smooth as those Beemers above 3000 rpm's but they were of course smoother overall.
trimming the front motor mount when it starts sagging is harley's answer to fixing the problem .....I noticed my vibes decreased somewhat when I replaced my primary chain tensioner. I am using a hayden unit now and really like it. Always going to be some vibration in the dynas but I dont find it unpleasant at all. Of course I started out with a 94 sportster that could rattle your fillings out of your head at freeway speed.. LOL good luck.
