Wheel figment questions
The hub should be the same I have been trying.to search for the exact answer. As for the axle size I am reading mixed things on your axle size. Best bet is to measure it up. The od of both bearing weather it's 1 or 3/4 is the same so worse case you get a new set of bearings. What color are you going to powder them? Coating my mags soon too.
@ matto 371 going to powder coat them black also my bike only has single disk so my friend mentioned to powder coat the side without the disk also
@ bigPete1 ya I figured would have to change spacing but my speedo is digital so should be good there. Now do you have any tips on figuring out what spacing size will be needed? Or just test fit and measure?
Thanks 99dynafxd
Thanks 99dynafxd
