1" lower kickstand install question
So I have a 2013 Street Bob. I recently purchased 11" progressive rear shocks and the progressive front drop in kit. I also ordered a 1" shorter kickstand.
My question is, how do I go about installing the new kickstand? Step by step instructions and/or pics would be really helpful.
Thanks guys
Chad
Thanks guys
Chad
no need for a shorter stand with this set up... if you really need more lean angle shave down the bump plate on the stock stand, works great to get a bit more lean... easier and way cheaper
https://www.hdforums.com/forum/dyna-...kickstand.html
I put the burly slammers rear and progressives up front...i kept the stock stand for about a year...if your parking on a level surface its fine but any sorta slope even the smallest and i was constantly worried it would fall over...when i would put the stand down the bike would roll forward a bit sometimes as well...i didnt want to modify the stand so i spent $50 and no worries..
I think with lowering the front and back, you would have more piece of mind with a shorter kickstand. Installation is pretty easy. I just removed the OEM and reinstalled as using reverse steps as removal. I haven't checked the Service Manual, but I'm sure they have step by step instructions...
