Fuel pump.
Fuel pump.
So don't know where to start. When I hit the on/off switch the fuel pump primes. Engine icon lights up. Bike fires right up. Been running into a problem lately. Switch on, engine icon lights up, but no priming from the fuel pump. Bike wouldn't start. Keep playing around with it. Take out the key, mess with the on/off few times and pump primes and starts right up. Not sure where to start looking for a problem. Haven't done any mods in a year or so. Everything seems to be getting power. Maybe a loose wire. Idk. all opinions appreciated.
Your run/stop switch needs to be replaced.
You stated that it won't prime, you turn off the key, play with the switch, turn the key and it primes and runs.
Mine was replaced under warranty, but mine was stuck in the on position and would not turn the bike off.
Sent from my iPhone using IB AutoGroup
Open the fuse cover and pull and clean your fuses and relays...they are probably corroded anyway so it won't hurt to do that.
Sometimes that is all it takes.
I would also check the connector on your ignition coil.
My bike was doing some funky things and acting up...eventually the ECM was the problem. It got to the point that it would't start so I replaced it with the Thundermax setup which was good and bad for me.
I will add that my bike always seemed to run funny from the factory. It had a miss to it at times.
I was able to tune it out with a Power Commander and custom map, but when I went to a Cobra system that relied on the stock ECM map to make adjustments the problem was back again. The Cobra works fine on my brother's bike so I know that it wasn't the problem.
I hope you find the fix, because I went through hell trying to diagnose my problem with tracing wires, changing fuel injectors (I had the old ones that needed replaced with the new style anyway) and most of the sensors.
