TW555 or S&S 583 cams in 103"
For those of you who have them, what do ya think?
There is only a smal chance i'll do a 107" kit and ported heads (fuel moto) but i aure am lusting for it, but dor now i'm doing cams, primo rivera pro clutch and lyndall disks.
Somebody also suggested s&s 585 cams . I'm looking for low-mid cams, been searching the forum for weeks.
What y'all think?
What y'all think?
Wolfmojo just had his motor done with the S&S 585's. He's got a 98" build with stage 2 heads though so I dont know how torque curve and numbers would compare to a stock 103" but here's a link to his post: https://www.hdforums.com/forum/12032362-post3023.html , looks like he ran off at 116 tq / 106 hp.
585s need compression so either headwork or at least something like new head gaskets and a Big Bore kit. Plus with that big of cam you may have to worry about valve/piston clearance using your stock flat top pistons. If you are not going to do headwork I would stick with a cam that has no more than about .560" lift and an Intake Valve closing no more than about 43 degrees on the cam specs.
I have the 583cams in my 07 dyna. Am really happy with the feel of the bike. Pulls really well. Was running a heavy breather intake and short shot pipes. Have attached the dyno chart. Got 100ft/ibs torque 85hp.
Have just put 106 kit on now and changed pipes to 2 into 1 comp pipe. Getting dyno'ed next week again.
Attachment 351800
Attachment 351800
