Will A 130/60/19 tire fit under the stock fatbob front fender?
Has anyone put a 19x3 rim with a 130/60/19 tire on their fatbob? Numbers wise it seems it will work but I am looking for personal experience. Also, has anyone put a 200/16 on the rear of a fatbob? thanks in advance for any and all help.
The stock front tire is 130 so no problem there. I'd be more worried about the change from 16" to 19". That would require an extra 1.5" between tire and fender, though you probably could just lower the mounting holes on the fender to raise it up, but again I'm not sure you have an inch and a half to work with.
I think it will fit fine. Im running a 130/70/18 on my Fat Bob. The overall diameter was actually smaller than the stock 16" wheel and Dunlop combo. I ended up with more gap between the tire and fender than I wanted so I drilled new holes and lowered the fender. So even if it was tighter than you wanted you could always do the same and raise yours a bit. But if your 19" combo comes out the same as mine you'll have more than enough room. Heres my 130/70/18 before I lowered the fender.
After.
And heres the mod for lowering.
Hope that helps.
After.
Hope that helps.
