Wheel bearing question
This might be a dumb question but i need to ask it...i have a set of cast wheels and im not sure which size bearings are in them..first is there an easy way to measure to find out? Should i change them out anyway reguardless? Do i need to change the front and rear bearings? Thanks...
When I put the new chrome Switchback wheels on mine I ran into a few problems with the wheel bearings. The wheels are machined for the "older" bearings, '07 and older use double roller berings that are wider. When they switched to 25mm in '08 the bearings are narrower. I had new bearing put in the SB wheels, the right side bearing sticks out 1/8" past the hub. I ended up machining down the right side spacer.
I do not have ABS the part numbers i listed are for non ABS but when i look at the picture of them they look exactly the same....so im curious on whats the difference if any..
joebotics
09-29-2013 05:16 PM
