CANBUS HD Lan Help
CANBUS HD Lan Help
I posted this in electrical but also wanted to post here since the dyna section is always so helpful. Ok so some jackass decided to vandalize my bike while it was put up for storage. They cut the wiring that comes out of the frame and goes threw the bars to the handlebar controls. How can I repair the canbus wiring? I have been told that I cannot solder canbus wiring. Is there a a replacement wiring harness I can buy or will I have to replace the entire switch housing? They are $225 per housing.
The best method is to stagger cut the remaining wires and use uninsulated butt splices covered with heat shrink tubing. You can get these and the correct crimping tool at Radio Shack. Depending on how much slack you have in the existing wiring, you may have to splice in extensions. Solder splicing will work also but it is more time consuming and not as good of a connection if you do not make a good mechanical connection by twisting the wire ends together first.
Good luck.
Good luck.
Took the harness apart today. Soldered all the wiring back together with silver solder and heat shrinked it all. So far everything is working perfect. All switches, lights, and dash work like they should. No canbus errors, no check engine lights, and no computer codes.
I need to go refresh myself on CAN-BUS, I think there's an article I have saved in AIM somewhere. I know I'll have to deal with it some day.
Matt
I see no reason you can't solder.
