U-bolts for enging guard?
Ordered a new engine guard because I was notorious for dropping the goldwing, the bars saved me a boatload. as I looked at the hardware that came with them I saw these nasty looking U-bolts, I just couldnt do it.
I came up with an idea and wanted some input from you guys.
I made a template out of 1/4 plywood which will bolt where forward controls would normally bolt. its 2011 fxdc Will this work, what type of metal?
Thanks for your input
Tom
Tom
I could be mistaken, but don't the bars that are designed for mid controls only bolt straight up to the forward mounts?? It seems that I saw both mounting designs for my SG when I was looking to replace mine recently but since I have forward controls, I didn't pay much attention to them...
Sammi
When I first saw the U Bolts, I too was worried about the design. They are actually quite solid. I needed the U Bolt design because I have Softail Footboard assemblies. Your adapter design looks promising and should be stronger than the U bolts, whether that is necessary or not, I don't know. I used 6061 Aluminum for the adapter plates for my footboard setup and I would recommend it for your adapters.
Bars for 2006 and up are more plentiful and cheaper than those listed for 2005 and below...if you can find one...and they look identical.
