Questions for you who added 7" headlight
I ordered the c01050356 7" chrome headlight from BKriders. It comes with the mount but I have a feeling from reading other post that I may want to bring it in closer to the frame.
For those of you that have done this what bracket did you use. (really don't want to pay $49.99 for the harley mount.
For those of you that used the same headlight, can you explain how you wired it in?
Thanks
Thanks
I got my 7" bucket off a Softail. The mounting block was nice and tight to the bike. If you dont like yours, can probably find a used one.
I also went with the LED from Trucklite Phase 7, its plug and play. The only issue was the light stuck out a bit from the housing, so added a frenched cuff and looks good. Great light.
The cleanest and easiest way to rewire your new light is remove the wires from the oem bulb socket with a small screwdriver (the pins are easy to release once you figure it out) then pull the wires out of the headlight. Mount the new light and feed wires back thru it and snap them back into the original socket.
blindrocket
09-03-2012 05:54 PM
