I have a 04 SG and would like to know my options to improve the front suspension..I am taking care of the back already with Works shocks. I was thinking of there spring kit also..is that a good route to go or is there other options i should look into?
Check out the traxxion straight rate springs with ricor intiminators thread
I went with a progressive front and rear 2" lower .... but greatly improved over stock. I was going for look over feel but in the end I got the best of both worlds
I put stock length Progressive springs (literally dropped in) and the front end hasn't been any better. Also using 10W Bel-Ray oil in the forks. My manual calls for 10.6 ozs. but I put in 11 ozs., much to pour that amount.
Yes I am looking for better than stock however i do not think i can afford a whole new front end so it would have to be able to use the current front end
Intiminators, straight rate springs and adjusters for under $500 = great results.
i get confused easily with this suspension stuff lol..i was looking at the intiminators and straight rate springs..what are the adjusters you are talking about?
Don't feel bad I still don't get all of it either and I've been researching it for a month and just did the install. Preload adjusters replace your stock caps and allow you to add or subtract preload on your front springs. Look into that thread, I know it's a lot of reading but there's a lot of real good info in there
