Sticky white stuff in breather tubes...
Well I dont think I've ever seen anything as weird as what I found last night... I was disassembling my AC to put on a new one from DK. When I got to the part where I pulled the hoses off the bolts, this wet stuff popped out across the support plate. It looked just like water but, upon looking at the tube closely there was a build-up of this milky white sticky stuff. It has the consistency of a lube or oil... the other tube had the same thing, like a water dripping out then a residue of that stuff. Looking inside the bolts, and into the housing, I couldn't really see anything like that in there so, not sure where it came from or what it could be. I'm about ready to have it sent off for a DNA sample... maybe then I can get some answers...
Don't worry too much about it. It is definitely moisture in your oil but in the winter you have to get it really hot for at least 30 mins to really evaporate out all the moisture. I have the same problem this time of year because my ride to work is 5 minutes. That's why every couple of days I make sure to take her for a long ride to get rid of that ****. Good idea to change your oil after winter though too. And always use synthetic.
