throttle / idle cable?
wondering which cable is which? i need to order the little clip that holds the cable into the throttle hand control and they sell them sepreatley because one is bigger diameter than the other. i need the smaller one which is the cable closest to rider when sitting on the bike. would that be considered throttle or idle cable?
thanks for the help guys. and it is not the ferrel im looking for. it is a clip that holds the outer cable sheath into the the throttle housing. is it safe/ok to get rid of it? i know most of my other motorcycles have only had one cable. if a cable broke the carb spring would shut the butterfly so i dont really understand why they have 2 cables.
It will be fine!! I've ran without the idle cable for 4+ years and never had an issue. Its there if the spring breaks on the Throttle body. I haven't heard of those snapping on a regular basis....ever. Carbureted cars or non drive by wire vehicles don't have a return cable and they have worked fine for years and years.
