soldering question
soldering question
Sorry, I haven't soldered anything in 45 yr. Can anyone guide me through the process and thinking, please? Relocating front turn sig on '13 Super Glide. Wires are not inside switches.
The tiny wires will have to be soldered while on the bike; my assumption is that I need to fashion some sort of platform and use a shop rag under the wire to keep solder from dropping on bike. Do you have any examples of a stable platform for this job? The instructions mention the ultra torch ut-100. Is the job much easier with an iron like this?
What options are there for heating the shrink tube that don't take a long time and are safe/easy for amateurs? Will a 1500 watt hair dryer really be adequate?
Thanks, very much for your help.
You are correct on the platform but a piece of cardboard will do. Heat shrink use a butane cig lighter.
Put the shrink wrap on first. (it's amazing how often over the years I have left it off)
Twist he wires linear with the ends pointing in separate direction and wound longwise over one another.
Put your rag under whatever you are soldering, Yes it will stick if it drips.
Using any electrical soldering iron, hold it against the wire in one spot and get the wire hot enough that when you lay the solder on the wire (not the bit of the gun) it draws into the wire. Repeat until done.
Use a longer piece of shrink-wrap than is needed.
If the wire is going to be covered from sight:
Shrink-wrap it. I use a lighter. Keep the heat moving.
Then I cover the shrink-wrap with liquid electrical tape. (great stuff)
If the joint is in sight:
Shrink-wrap it and call it good.
If your getting dripping from the solder your using too much. I use an inexpensive soldering 'wand' that looks like a fat pencil. That inexpensive thing has been awesome. Practice on a few wires before digging in and you'll notice how small amount of solder you need on the wires. Don't put so much on that its fatter than the thickness of the wire insulator. If you cant slide the thin piece of shrink tubing over the solder, your still too thick.
I would use a soldering iron. Not a torch to solder your wires. Place the heat shrink on first. Use flux core solder. I also dip the wire ends in flux, it helps the solder flow where you want it quicker. Use a lineman or flat nose plier and squeeze the joint to flatten any rough solder before you slide up the heat shrink. Then I use a small BBQ lighter to shrink the tubing.
