Power Vision Tuner - What's on your display?
So I just got a Power Vision PV-1 and installed it on my Fatbob. I'm browsing through all of the features and display screens and am wondering what screens / gauges you guys have found the most useful to monitor while riding. Also, I temporarily mounted mine on the lower tank bib and am waiting for a couple of mounting pieces to arrive. If you have any pics of your setup and even how you mounted the unit, that would be helpful. Thanks!
I have Speed, RPM, MAP, AFR, Head Temp, and fuel used on mine. I made a mount that I attached to my handlebar bag. Can shoot a pic of it tonight. It's just a piece of sheet metal that I drilled 4 holes in that matched the 4 mounts on the back of the PV, bent it about 30* and then bolted to the handlebar bag. Made a piece of leather that flips over and tucks under the PV to keep it protected from the sun and outta sight.
Speed, RPM, head temp, charging system, front and rear wide band o2(if you have AT pro). Another cool feature is setting hi and lo values, when the reading exceeds preset limit, it will give you a warning. How cool?
I don't remember whether you have ape or not, if you do check out my mounting.
It is detachable but I leave it on there all the time.
https://www.hdforums.com/forum/dyna-...rmanently.html
https://www.hdforums.com/forum/dyna-...ion-today.html
Dim picture, sorry, but this is my cockpit. Cordless radar detector on top, PV mounted on a RAM mount to a crossbar between my fairing brackets.
I keep the 6-cell display up most of the time with Temp, Trip Mileage, Trip fuel used, Speed, RPM, and Gear. I don't even look at my speedo anymore. Once I get it relocated to the bars, I might use it again. In the meantime, PV keeps me in line.
