Licence plate relocation on 2014 Street Bob
Has anyone done it? I know the 2013 had a bracket that was easily removeable but the 2014 has the plate mount integrated into the left taillight mounting assembly. As it stands now, if I just remove the plate mount from the taillight, the left taillight will be shorter than the right. As far as I can tell, I either need to cut the plate assembly away from the spacer tab between the taillight and fender, with my side grider, or buy another taillight like the right side that has a standard length post.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
You can buy just the stalks on Ebay or from the dealer. Stalks from myst Softail, Sportsters or othe Dynas work. http://www.ebay.com/itm/HARLEY-DAVID...56c520&vxp=mtr
There are many to choose from on Ebay. They even have single if you don't want a pair. I'd recommend buying the pair just in case there are minor differences.
Also, I have a thread for a very clean looking tail mount for your plate. Let me see if I can find it.
Finally, don't cut the wires like I did. Look for Molex disassembly on YouTube. It's very easy to take the connector apart if you know the trick.
The '13 and '14 are the same. A shorter stalk on the left to make space for the LP bracket.
I think you mean to say, I don't know what YOU'RE talking about! The bracket might be different, but the install is the same, so there! Take that!
