new exhaust on my 2014 streetbob question
Old 01-31-2014, 05:34 PM
woody1978's Avatar
woody1978
woody1978 is offline
Default new exhaust on my 2014 streetbob question
hey guys, I just recently purchased a new 2014 dyna streetbob, first thing I want to do is get rid of that stock exhaust, I'm looking at the vance and hines big shots, my question is, do I need to upgrade the air cleaner and put a upgraded fuel pak in for my bike to run properly with the new exhaust? thanks very much, any help would be muchly appreciated.
Old 01-31-2014, 05:36 PM
Flinter's Avatar
Flinter
Flinter is offline
The consensus that I've seen on this forum is that you can change the pipes OR the air intake and not worry with a tuner. Personally, you will end up doing it all anyway, I'd just bite the bullet and do it.
Old 01-31-2014, 05:37 PM
Robbie13's Avatar
Robbie13
Robbie13 is offline
LOSER
Congrats! Tons of threads on this. The consensus seems to be if you do just the exhaust you are fine. If you do both a tune is recommended.
Robbie13's Avatar
Robbie13
Robbie13 is offline
LOSER
His internet was faster than mine.
Old 01-31-2014, 06:09 PM
high rpm launch's Avatar
high rpm launch
high rpm launch is offline
Exhaust or air cleaner is going to further lean you afr. Bikes are lean as hell from factory. Anything you do, new high flow exhaust or highflow ac will require either HD flash or piggyback efi tuner.
Old 01-31-2014, 11:05 PM
Pistonman1's Avatar
Pistonman1
Pistonman1 is offline
HD flash does squat
Old 01-31-2014, 11:21 PM
Flickerdart1's Avatar
Flickerdart1
Flickerdart1 is offline
Originally Posted by Pistonman1
HD flash does squat
...The dealer will disagree with you------that's only because he stands to make good money for downloading "squat" !
Do yourself a favor and tune the bike with a proper tuner............Cheap is only for todays satisfaction , for permanent happiness , do things right the first time .
dudeboy72
10-22-2013 10:24 PM
jluna1991
04-24-2013 10:37 AM
Matt1200R
01-11-2013 10:33 PM
mustangderek22
07-22-2009 05:40 PM
fedwa001
10-06-2008 10:19 PM
Quick Reply: new exhaust on my 2014 streetbob question
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
