Brake Light Problems
Ok so I am sure I am missing something here but I worked on my 2007 Wide Glide, took apart the front end, put it back together and now my brake light will not illuminate. I checked the bulb and it is fine, I checked the fuses and all of them are good (minus the relays not sure how to verify if those are good or not, but nothing is outwardly wrong with them), and I checked all of my work that I did and everything was put back together in order and in place. I have been through my owners manual multiple times and am at a loss. Please for the love of God someone point me in the right direction!
Thanks in advance.
Thanks in advance.
My guess is that you didn't put together one of the switches properly and your brake light is actually staying on permanently. In other words, what you're thinking is your taillight is actually the brake light. That would happen if for instance you took out the tiny clip in the front switch housing.
Yes dissaembling the front break lever is tricky. You may need to just adjust the switch in the lever, or you may of broken it. Easy to break. Not the best design.
I was kucky when I removed mine, some are not.
I purchased a new one for about $25.00 and keep it as a spare.
You need to shim the lever upon dissasembly or risk breakage.
@Racqueteer9
When I pulled the bulb and checked it I saw only one of the coils illuminated. It was the one that was furthest out not sure which one of them is the tail light but in my mind, and tell me if I'm wrong, aren't both of them illuminated for the brake?
@stilup
I am going to pull apart the front brake lever again and check to make sure I didn't break the switch. Definitely my style to do that! I will let you guys know what I find.
Again thanks for the input.
@stilup
Electrical problems can be annoying but are not all that difficult to find and fix if you do this...
Identify exactly what is happening correctly and what is not.
Retrace your steps. Start where were working. If the brake lights were working when you started on the front, then it is not logical that the problem would be in the rear unless you worked there also...the problem will most likely be in the area you were working in so, what exactly did you work on in the front?
Get a wiring diagram and trace the rear brake light circuit focusing on how what you worked on in the front could have affected the rear brake lights? If you do not have wiring diagrams, there are wiring diagrams posted on this forum, search for them.
...and always remember, Murphy's Law...
Good luck.
Good luck.
