Screamin Eagle Heavy Breather Install
One of my winter projects with a few pictures of show and tell.
I like to take my time with things and enjoy the time/process of working on it. So Id say this a 3 beer job. When I started I had no intention of finishing it in the same sitting and had planned to just lay it out and pull the old AC off. All in all was about 1.5 hrs.
Very simple install and everything went very smooth with no surprises.
Hope you enjoy!
Hope you enjoy!
I just installed this kit last night and noticed an extra plug that was in the back of the stock breather backplate. What did you end up doing with that wire after you installed the SE Heavy breather kit? I'd like to put a cover on it and tuck it under the tank, but wasn't sure what it was for or if I'd ever need access to it.
Just did the install on my 2014 48. The Chrome Breather (bolt) Plugs have a flat just behind the head before the 1st o-ring groove. Does this flat have something to do w/ letting air in & out (breathing)? Also, where should it be positioned - what position on a clock should it be positioned?
