Phone charger on an 07
do you have a battery tender hooked up? I just bough a 12 volt adapter and plugged it in, ran the wire under the tank and zip tied in front of the tank. Then got a USB adapter and use my iPhone cord. put the phone in the RAM mount and works great.
do you have a battery tender hooked up? I just bough a 12 volt adapter and plugged it in, ran the wire under the tank and zip tied in front of the tank. Then got a USB adapter and use my iPhone cord. put the phone in the RAM mount and works great. Video Link: http://www.amazon.com/Battery-Tender-081-0069-8-Cigarette-Disconnect/dp/B0041CDPQO
Here you go, $7.50 on the battery tender website:
http://batterytender.com/products/ac...l-harness.html
I just tuck the end in under the seat behind the battery box area so i can unplug charging cord for phone and plug in battery tender if i need to
Amazon.com: 12V Cigar Cigarete Lighter Power Supply Car Charger Plug Socket outlet motorbike: Car Electronics
something like this is an option as well
