handlebar switch clean up
Old 02-06-2014, 12:53 AM
Wideglide_Steve's Avatar
Wideglide_Steve
Wideglide_Steve is offline
Default handlebar switch clean up
I've been looking for way's to clean up my handlebars and get the switches off the bars. Maybe put them somewhere else. But, not sure how or where to put them. I have a 05 wide glide by the way. Just seeing what you guy's have done or options you have. I searched the forum but, couldn't find anything.
Old 02-06-2014, 07:48 AM
Muddyape's Avatar
Muddyape
Muddyape is offline
If you dont have it already buy the service manual and start looking at some wiring diagrams. I did what your asking about but also got rid of my blinkers and horn. Not because I couldnt move the wiring...just didnt want them anymore. Youll have to jump the nuetral bypass switch (I did mine right at the connection in the frame) My on/off, high beam and start switches are now on the center console of my 07 SB. Not hard but not easy but well worth it.
Old 02-06-2014, 08:01 AM
SLV's Avatar
SLV
SLV is offline
That's pretty slick. Do you find this setup convenient?
OP. I can't remember the name of the product, but there is a switch assembly that is built into the handgrips. Basically just flush button on the grips themselves. I'll see if I can find it. It looks great without actually relocating.
Old 02-06-2014, 08:05 AM
SLV's Avatar
SLV
SLV is offline
http://cyrilhuzeblog.com/2009/03/27/...witch-bar-kit/
This is the one I was thinking about.
Old 02-06-2014, 10:56 AM
Wideglide_Steve
I took off all my blinkers when I first got the bike. I really like your idea of putting the switches there. What about making them hidden by the seat or under the tank?
Old 02-06-2014, 10:58 AM
Wideglide_Steve
I saw that but, from what everyone keeps saying you can't run a front brake with that set up.
Old 02-06-2014, 12:14 PM
jlresq06's Avatar
jlresq06
jlresq06 is offline
You can change out to a banjo bolt brake light switch
Old 02-06-2014, 02:17 PM
rgb66's Avatar
rgb66
rgb66 is offline
Why? Because of the way it's mounted on the black handlebars pictured?
I still think that is pretty cool and it sure would clean up things. Though in most cases I tend to go the direction of Muddyapes's solution. Something I can fix with the tools in my jacket pocket.
Hey Man
Electrical/Lighting/Alarm
07-07-2018 12:15 AM
trafficlaw
06-01-2014 02:56 PM
Joe376
02-09-2008 12:18 PM
TexasRedneck
03-30-2007 11:47 PM
Quick Reply: handlebar switch clean up
