Starter ring gear
Starter ring gear
I have an 03 Lowrider and the pinion gear is shot. There are 2 teeth completely gone. It needs to be replaced but my concern is the starter ring gear. There are 3-4 teeth that are worn down, the rest of the teeth look fine. I can not find any wear limits anywhere in the manual. According to Harley you have to replace the clutch shell which is $4oo. I really just want to replace the pinion gear but if it will cause more damage I will replace the starter ring. Any input will be appreciated.
They are bolt on items, if you trash one on the road, you are not not forced to use the same ratio, you use whatever ratio ring and pinion set is available.
Been doing some more research and after really looking at the ring I just wouldnt feel comfortable keeping it in there. From what I've seen I have to pull the compensator and the clutch assembly. Then drill out the rivets on the ring, bolt the new ring on and throw it all back together. I think I can handle that.
Don`t attempt pulling the clutch shell assembly without removing the compensator. Just do it the right way.
