Help! Removing Rear Turn Signals!
I am stumped. I have unbolted the housing and stem but obviously the wiring runs inside the fender. I have tried to deconstruct the signal housing to free it from the wires with no luck. I am about to cut the wires and then will just have to soldier them back together after painting my bullets.
Any other ideas or tips? Help!
He has no tail light. The wires run all the way to TH electrical bundle under the seat.
OP,
Did you get the reflector out of the housing?
If not, do this.
Take off the lenses with a flathead screwdriver in the groove on the side of the lens.
Take out the bulb by pushing and turning.
Make a hook from a stiff wire like a coat hanger. Use it to pull the plastic reflector from the housing.
Toward the back of the reflector, on the square shaped section, you'll see the flat edge of a piece of metal about 1/8" wide. It is a sprung clip. Push that in while gently pulling the wire. It comes right out.
Alternatively, at the other end of the wire, you can disassemble the Molex connector. Search YouTube for Molex disassembly. It's easy once you know how it works.
OP,
If not, do this.
I just did this a few nights ago..pull seat off disconnect the harness then jack bike up abit just to take some weight off rear..start on lower shock bolts..then once you crack the tension jack bike abit more untill its a hair between tire and ground..remove lower shock bolts then as your rear tire touches ground jack bike until the bolts can clear the rear tire..hold the signals housings while you pull the bolt out then feed wires through the fender..it will come right through the hole..then voila..reverse to put it all back togeather..it tool me awhile to find this info so i figured it write it anyways for the next guy that will be looking for the same info haha but by the way i see what your saying now.. gutting the light housing is what you meant..that i didnt do
