Clutch Hub Nut/Compensator Sprocket Nut
I believe the clutch hub nut was 1 3/16".. totally forgot what the comp sprocket bolt is. If I were to just shoot from the hip, I'd say it was something like 13/16", but not sure. I just tore mine apart 2 weeks ago on my 2006 Bob to change out the infamous inner primary bearing... which I would definitely look over once you remove the inner primary case. I don't have the manual with me right now.
According to this instruction sheet:
1 3/16” SOCKET (CLUTCH NUT REMOVAL)
1 ½” SOCKET (COMPENSATING SPROCKET NUT)
Some useful tips to be found in this thread by mud:
https://www.hdforums.com/forum/dyna-...ensator-2.html
