11.8 Brake Caliper??
http://www.jpcycles.com/product/245-035
Anyone know if it will fit a 13 street bob?? question is if im replacing a caliper and rotor can i change it to a 11.5?
Pretty certain it will, don't think much changed on the forks for a while... It's probably the left you want no?
http://www.directcycleparts.com/brak...ck-p-6792.html
Yup. If you're changing both there's no reason you'd have to stay at 300mm
See, I was thinking that it would NOT work because you're still mounting the caliper to the same mounting points. So, your pads wouldn't be lining up on the rotor properly. This is purely an assumption as I have no experience or knowledge of a swap like that. Hopefully someone else can chime in that knows more because I'm also a little curious now...
From JayBrake website:
Jaybrake's J-Six are designed to mount directly onto Harley front forks (except Springers) without having to change the brake lines. They are designed to fit 2000 and up with 11-1/2", 300 mm and 13" rotors. They are available in Extreme or Ultra designs
11-1/2" & 300mm Rotors:
MSRP: Polish $379.95, Chrome or Black Anodize $399.95
13" Rotors:
MSRP: Polish $389.95, Chrome or Black Anodize $409.95
Looks like the same caliper is used for both 11 1/2" and 300mm (11.8") rotors. Which makes sense since if you look up the Harley part numbers for calipers used in 2005 with 11.5 stock rotors and 2006 with 11.8 stock rotors they are the same number.
I am by no means an expert so don't go spending $800 before you confirm this though, lol. Im sure if you call Jaybrake they can confirm.
Heres a link to the JayBrake page: http://www.jbrake.com/brakes_extreme_ultra.html
13" Rotors:
