Shifter shaft seal 2010 dyna
Hi,
Have leak at inner primary seal so in the process i am replacing the shifter shaft seal
shifter shaft broke up into pieces on removal with a pick, very difficult to get all of it out, could you run a bit of sandpaper in the area to clean up or just wipe with acetone or something and insert new seal?
What about using a bit of silicone once seal is re-installed?
Thanks
Mirrmu
Thanks
Mirrmu
hi,
this is the new and old inner primary seal, 33000kms on the fxdwg:
mainshaft, i measured the race and looks like its within spec, the bearing in inner primary rolls well:
shifter shaft area after I have cleaned up as much as I can, it was very small what was left and wedged right in there, amazed it wasnt leaking:
new harley shifter shaft seal, looks like made by NGK, will check which way it gets installed:
just couldnt get a good photo of the other side of the shifter shaft seal:
got new primary to motor gasket and 5 fasteners, it was very evident the inner primary seal was leaking once i got primary off
thanks
mirrmu
thanks
mirrmu
Edit: Tool for shifter shaft seal
Matt
Hi,
I am replacing both seals
The inner primary seal was leaking
I was careful picking the shifter shaft seal out but a bit of residue of seal still there
Edit: just seen your post on the other inner primary leak thread so i will have a look around the main shift a bit more
Thanks
Mirrmu
Thanks
Mirrmu
